dnpark38
Message 1 of 2
New to BT any settings I should change?
Now gone active and I'm wondering if I should change any of the settings in the Hub or my Account to benifet me rather than BT?
1 REPLY 1
Message 2 of 2
Re: New to BT any settings I should change?
The only settings to change are disable smart setup and split the wifi bands. Other than that the hub is completely locked down and there are no chnges you can make.
