familydogg
Message 1 of 3
New user of HH5
I have just received my HH5 and the connection is due totake effect tomorrow.
A possibly simple query.
I am just puzzled why the instruction pamphlet seems to assume wireless use?
I am much happier using a wired connection but it is puzzling 'Finishing your set-up' is almost exclusively about wireless.
Is it just the way I'm reading it (there is a wired set up diagram), is it because wired connection is so simple or is wireless the preferred method of BT?
Thanks for what may be simple help if you offer it.
2 REPLIES 2
Message 2 of 3
Re: New user of HH5
the vast majority of customers have some device that will conenct to hub wireless whether smartphone or ipad or tablet or tv
Message 3 of 3
Re: New user of HH5
I suppose it is because wireless needs a certain amount of configuration requiring instructions whereas Ethernet is just plugged in and doesn't.
