Message 1 of 1
Nintendo Switch OLED connection to BT Wifi Smart Hub 2 - please help
Hoping someone has found a solution...
I live in a small flat myself and the BT wifi works great. Never had any down time or slowness.
I recently purchased a Nintendo Switch and for whatever reason, it refuses to connect to the wifi. However, it does connect to a BT Wifi Hotspot... this makes no sense to me. Issue with this is it is definitely slower and I have to log into the hotspot every time I put the switch on or I lock the screen.
Just wondering if anyone has had a similar issue? the error the nintendo switch shows is that I have entered the password incorrectly and/or the network connection isn't strong enough. Has anyone found a resolution? I have tried turning on and off the web protect and standing next to the wifi with all other devices disconnected.
