wrel
Message 1 of 27
No broadband connection BT fail to connect me
New cutomer to BT, supposed to go live on the 8/5/18, have a land line but NO broadband. BT say is't a software issue wetween them and wholesale.  Anyone else having this propblem this month.
26 REPLIES 26
Message 2 of 27
Re: No broadband connection BT fail to connect me
so phone line works ok with correct number?  are you changing to BT from another ISP?
wrel
Message 3 of 27
I switch providers and opted for a deal from BT, phone line and broadband, they switched the land  line and it works, but they have failed to connect the broadband. I have made several calls and complaints, I am told it's a software problem, BT placing the order to WS (Openreach). I was wondering if anyone else was experiencing the same lame excuse BT are giving me.
Message 4 of 27
can you enter your phone number and post results  remember delete number  http://dslchecker.bt.com/adsl/adslchecker.welcome
are you trying to get infinity or copper/adsl?
wrel
Message 5 of 27
I had fibre broadband before switching, with Plusnet. I live of a new estate, less than 5 years old, all the houses have the latest connections. This is a BT and Openreach problem.... they are not communicating together, one party keeps blaming the other.
Message 6 of 27
did you try the link?  if so did it show that FTTC was available and not waiting list?
it is possible when you move ISP if your cabinet was full with waiting list then moving even if you had a fibre connection that would not transfer with you  your connection would go to next person on waiting list and you would join waiting list    so important to check the link I posted to make sure no waiting list
If it is ok then we can see if mods will help to at least find out the delay and then help
wrel
Message 7 of 27
Yes I did try the link and yes it is available.....
Featured ProductsDownstream Line Rate(Mbps)Upstream Line Rate(Mbps)Downstream Handback Threshold(Mbps)WBC FTTC Availability DateWBC SOGEA Availability DateLeft in Jumper  High Low High Low        Featured ProductsDownstream Line Rate(Mbps)Upstream Line Rate(Mbps)Downstream Range(Mbps)WBC FTTP Availability Date   ADSL ProductsDownstream Line Rate(Mbps)Upstream Line Rate(Mbps)Downstream Range(Mbps)Availability Date Left in JumperOther Offerings     Availability Date   Premise environmentStatus
VDSL Range A (Clean)44.331.88.55.727.4AvailableAvailable--
VDSL Range B (Impacted)3519.97.94.215AvailableAvailable--
FTTP on Demand33030--Available----
WBC ADSL 2+Up to 6--4 to 8Available----
WBC ADSL 2+ Annex MUp to 6Up to 14 to 8Available----
ADSL MaxUp to 5--3.5 to 7.5Available----
WBC Fixed Rate2----Available----
VDSL Multicast------Available----
ADSL Multicast------Available----
Bridge TapU
VRIN
NTEFaceplateN
Last Test Date16-05-2018
Message 8 of 27
I have asked mods to see if they can help   they will post here
wrel
Message 9 of 27
Thanks.
Moderator
Moderator
Message 10 of 27
Hi @wrel
Welcome to the community and thanks for your post!
Sorry for the delay connecting your broadband since requesting to move your services over to us.  I appreciate the time you have taken to contact us about this.
We can pick this up and check what's causing the hold up and help get you connected.  Click on my username here >> RobbieMac << and you'll see our contact link underneath my profile picture.
Cheers,
Robbie
