Yeboiiii1
Message 11 of 18
Re: No internet acess on desktop pc
I have an old laptop ffrom 2008 incould try but other than that my desktop is the only pther windows machine in my household, ill try the laptop
Yeboiiii1
Message 12 of 18
Okay so the same issue on the laptop  connected but no internet access.
licquorice
Message 13 of 18
Just as a long shot, connect the powerline adaptor to a different EThernet port on the hub. If that doesn't work, it would appear that the fault lies with the PLAs.
gg30340
Message 14 of 18
So obviously not a problem with the PC.
Carry out some more diagnostics.
Move the slave adaptor down stairs and plug it in there and see if you can access the Internet on the laptop.
imjolly
Message 15 of 18
I assume If you did reset the powerline adapters to factory settings did you then re-pair them before using?
lnajr02
Recognised Expert
Message 16 of 18
Type of power lines
Led status showing on power lines?
gg30340
Message 17 of 18
@lnajr02 wrote:
Type of power lines
Read message 4
ceperman
Message 18 of 18
"The default gateway is not available" suggests the powerline is not getting through to the router.
Stupid question: is the powerline adapter at the other end connected to an ethernet port on the hub?
I have a similar setup for my PC using a Devolo powerline - works just fine.
