SteveSnook
Message 1 of 11
Non BT router and BT OpenReach
I am replacing my BT home hub and router with a non BT modem/router. However the new rouetr does not detect the DSL input. Is there a compatability problem when using non BT equipment with BT OpenReach?
10 REPLIES 10
licquorice
Message 2 of 11
Re: Non BT router and BT OpenReach
No, but are you sure it is a VDSL modem/router if you have Infinity rather than an ADSL modem/router. What is the exact make and model?
SteveSnook
Message 3 of 11
I have an ADSL Router - should it be VDSL?
licquorice
Message 4 of 11
If you have Infinity, yes.  What does the Hub show for modulation type?
SteveSnook
Message 5 of 11
The BT Router is VDSL
imjolly
Message 6 of 11
the BT hubs 5 and 6 are both adsl/vdsl  if hh4 or earlier then only adsl
SteveSnook
Message 7 of 11
looks like I need a VDSL router/modem if I am to replace the two BT devices (modem and home hub).
Technonerd
Message 8 of 11
Just to get this straight. Are you trying to use a router with a VDSL modem with the Openreach modem? If so, you don't need the modem, you can just use the router.
SteveSnook
Message 9 of 11
combined router/modem however the router I have is ADSL
Technonerd
Message 10 of 11
Right, I gotcha! So, you have a 3rd party ADSL router, and a BT VDSL router. If you want to use the ADSL router, you need to set it up in bridge mode to work with the Openreach modem. Or, you can use the BT router or buy a 3rd party VDSL router.
Hope that makes sense.
