Mikeontheedge
Message 1 of 8
Non bt router and vpn
Can I switch to an asus RT-AC3200 easily?
And can I then install a vpn?
I'm aware I can't install one to my HH 6.
Mike
Tags (1)
7 REPLIES 7
licquorice
Message 2 of 8
Re: Non bt router and vpn
Not without a separate modem, no. That device is just a router not a modem/router.
Mikeontheedge
Message 3 of 8
Thanks for the reply, I could use Mt hh6 as the modem?
Liam_
Recognised Expert
Message 4 of 8
Hubs don't do modem only.  You would need a VDSL router or a separate modem with the Asus you picked for things to work properly.  Either a DrayTek Vigor 130 or a Netgear DM200.  The DM 200 is a limited capability router though it can be used as a modem only.  You might still get a used Openreach modem from ebay.
Mikeontheedge
Message 5 of 8
Is there any reason I can't continue to use the HH as a modem, turn off DHCP and WiFi on the HH, connect the tplink router to the HH via ethernet, and use the tplink to provide DHCP and VPN to the other devices on the network?
Liam_
Recognised Expert
Message 6 of 8
You can do that if you like but you end up with double NAT and the associated issues that will cause.  Then you basically end up using a perfectly good router as an access point.
Mikeontheedge
Message 7 of 8
Once again Thank you for the response.
Relative noob here so appreciate the advice.
Mkke
peaslaker
Message 8 of 8
BT Openreach VDSL modems (ECI or Huawei) go for £15 secondhand on Ebay.  The router you partner with it needs to be capable of a PPPoE connection (most do).
You need to give a user id to the PPPoE settings page.  The usual advice is to use:
User: bthomehub@btbroadband.com
Password: BT
The above has worked for me.
