drtrouthair
Message 1 of 4
Not connecting to BT 750 Wi Fi Extender
Hi Folks,
Recently I purchased a 11ac Dual Band Wi-Fi Extender from BT, for the kitchen. However we are unable to join it on any of our devices. The device thinks about it (spinning wheel timer) but never actually logs on.
Any ideas?
Cheers,
Fraser
3 REPLIES 3
Moderator
Moderator
Message 2 of 4
Re: Not connecting to BT 750 Wi Fi Extender
@drtrouthair did you manage to get this sorted? Do the instructions in this video tutorial help?
Community ModeratorNeilO
Show your appreciation!
Kudos”Kudos”
drtrouthair
Message 3 of 4
Unfortunately not.
Having had dialogue directly with BT it seems I have a faulty unit which needs to be replaced/returned.
Moderator
Moderator
Message 4 of 4
I hope the replacement helps you @drtrouthair.
Let us know how you get on.
DanielS
Community ModeratorDannyS
Kudos”Kudos”
