gg30340
Message 11 of 25
Re: Off-line networking
On the XP machine, make sure that you have up to date antivirus protection and that the Windows firewall is turned on. If all you intend to do is connect to your wireless network printer in order to print and you are not going to "surf" the Internet you will be very unlikely to have a problem.
You can use any of the well known brands of antivirus that offer free protection.
Turn on the wireless connection on your XP when you need to connect to the network printer. Once you have finished with your printing just turn off the wireless connection on your XP machine which will isolate the machine from the Internet.
Anonymous
Not applicable
Message 12 of 25
@Scotsail
You might find this article interesting
Edit: Skip down to Bullet Point 4
gg30340
Message 13 of 25
@Anonymous wrote:
@Scotsail
Why would he want to disable the firewall?
Anonymous
Not applicable
Message 14 of 25
@gg30340wrote:
@Anonymouswrote:
@Scotsail
Who didn't read bullet point 4 then?
The Windows XP Firewall can be set to allow local traffic whilst blocking internet access
gg30340
Message 15 of 25
I did and the question is still relevant, why turn off the firewall?
Anonymous
Not applicable
Message 16 of 25
I'm not saying he should, I'm saying he can set the firewall to block access from the internet and still be able to communicate with his own network devices.
gg30340
Message 17 of 25
I am aware of what you are trying to do but unless I am mistaken the article was for turning the firewall off and not for having the firewall turned on to block all connections to and from the Internet while allowing exceptions through on the LAN.
Scotsail
Message 18 of 25
Thanks licquorice, have seen some of you earlier posts on the subject. Agree it shouldn't need a broadband conection but it alternates between a very strong wireless signal and nothing at all, so can't print. Incidently, although I print successfully with Win 10 PC, the printer does not appear on the list of devices in the hub list
Scotsail
Message 19 of 25
Thanks V-M. I do have the original, very old, media and, when I tried initially to install it, it was rejected. The hub is indeed a 6. What is particularly annoying is that,during lockdown I held on to the old hub and only recently returned it for recycling. To add to my troubles, my numbr 2 mouse has died so further experimentation on XP PC is paused.
Scotsail
Message 20 of 25
Thanks gg and V-M for the interesting discussion. I have always disconnected from my Broadband link before activating a wireless connection in XP, because I feared virus infection. Advice from both of you suggests that I can have a continuously active wireless connection without going on line. In that case, as a purely academic question, is it necessary to have updated anti-virus or is it irrrelevant?
