gg30340
Message 21 of 25
Re: Off-line networking
If you are at NO point connecting to the Internet or installing untested software or untested USB drives you do not need to have up to date antivirus. That is assuming that the other devices on your own network (LAN) are all protected so that they can not become infected and then infect unprotected devices on the LAN.
Anonymous
Not applicable
Message 22 of 25
It depends on what protection you have on your other network devices, BT Protect (AKA McAfee) isn't brilliant, in fact I've found the free version of Avast to be better. Imagine if you don't have an AV on your XP machine and you get a virus on one of your other network devices, your XP machine would be unprotected.
Scotsail
Message 23 of 25
Thanks, have no need to connect XP to internet.
Scotsail
Message 24 of 25
Windows 10 has BT Protect, will look at Avast, thanks
gg30340
Message 25 of 25
As has been said, Avast Free gives good protection and the Windows 10 on board virus protection Microsoft Defender is now getting good reviews.
