AF1
Message 1 of 17
Ongoing Device Net Disconnects
Hi, I  had issues for over 8 months with my Sky HD+ box losing its connection with the Smart Hub on both WiFi and Cable - sometimes twice a night - which is a known issue with Sky HD+ boxes.
Having been denied a new HD+ box because they don't have any or a Sky Q box, I cancelled my subscription and took out a new one.
The new Sky Q box did not cure the problem.
Following advice on the Sky forums I swapped the BT Smart Hub for a new Hub 5 off ebay.  All my Sky box disconect problems were solved.
However I now have another device disconecting and failing to re connect. And a device is being reported as disconnected when it is in fact connected in the router settings. Its a printer and it prints fine!
I havent had a Sky box disconnect in the past month since fitting the HUb 5 so it was obviously a faulty Smart Hub so I asked BT for a new Smart Hub.  They have refused.
I contacted Executive Level Complaints but received no response.
What should I do?
16 REPLIES 16
Keith_Beddoe
Message 2 of 17
Re: Ongoing Device Net Disconnects
Just use the HH5, forget about the HH6, or use a third party router instead.
AF1
Message 3 of 17
Hi Kieth
Thanks for the response.
However, as I said, I am having issues with the HH5.
imjolly
Message 4 of 17
 I have a hh6 with 2 sky hd+ boxes connected using power line adapters and never have any problems with losing connection and catch-up works without a problem. You can try again to get a replacement both from sky and/or BT
failing that I would get a third party router and popular on forum is tplink 9970 about £30
Keith_Beddoe
Message 5 of 17
@AF1 wrote:
Hi Kieth
Some home hubs do seem to have issues with some devices. Investigations I did with the earlier home hubs, indicated that the DHCP table within the firmware, was just filling up with entries, and "forgetting" some devices.
This could only be fixed by a factory reset of the home hub, or in the home hub 1, a reload of a default configuration file.
I am not sure this issue has ever been fully addressed, as some people still get disconnects.
@imjolly has been lucky with his combination of devices, that he has no disconnects, but I think there may be two versions of the HH6 in circulation.
The only way to really prove whether it is a home hub and device incompatibility, it to try a third party router, like the £30 TP Link one, which I use.
I have never seen any disconnects on all of our devices here, or any our neighbour uses, connected to the guest network.
I have a mixture of Android phones and tablets, a Cannon printer, Fire TV stick, BT YouView box, and three different laptops.
My neighbour has all Apple stuff connected by wireless, and there have been no disconnects. I can see the wireless status screen on both maiin and guest networks.
 Example showing connected wireless devices on main network
Example of devices connected to guest network
AF1
Message 6 of 17
Yes, a quick trawl shows there are loads of people having disconnects with HH6.
Some have advised switching all devices off before factory reset, then switching Sky back on first. I did this with HH6 but have not tried it with HH5 yet.
Its a pain having to do factory resets what with setting, passwords etc.
My HH5 DHCP table is full of many legacy devices so I'll def do this.
Why does it need a list of disconected devices anyway?
When will BT a) admit this issue & b) sort it out?
I take it Keith that you think the HH6 or at least one version of it is defective and not worth persevering with?
How can we tell if we have the defective version?
imjolly
Message 7 of 17
you can't tell if you have a faulty hh6 until you try it  there seemed a batch of problems at one time suggesteing a bad batch of hh6 but bearing in mind how many hh6 are in use they can't all be bad otherwise  it would be all over the press - and the HH6 I use works without a problem
Keith_Beddoe
Message 8 of 17
They are retained in non-volatile flash memory, for reasons best known to BT. I think its the result of using some legacy SpeedTouch code, as this issue was also present in the home hub 1.
Eventually it fill up, and cannot accept any more entries.
You would expect the DHCP table to be cleared by a restart, but its not.
AF1
Message 9 of 17
Keith said "bearing in mind how many hh6 are in use they can't all be bad otherwise  it would be all over the press"
I think there's a lot of people who never complaint and don't go on forums etc.  My son is one of them - he's on his fourth HH6!!
Dunno how he managed it - they won't give me a 2nd one!
Keith_Beddoe
Message 10 of 17
It was @imjolly who said that, not me Smiley Wink
