h3x1e
Expert
Message 31 of 40
Re: Online gaming lag
No my own router doesn't make a difference to the issue, however I think your issue is different to the other "gaming latency" threads.
We can actually pinpoint latency issues on specific BT nodes (or so we think)
Joseph90
Message 32 of 40
Traceroutes are easy to understand. Hop 1 is your router hops 2-6 are usually the bt network and every hop past 6 are the destination your packets are being sent to i.e gaming servers. If High pings are showing in hops 1-6 the problem is with the router or BT network and if high lag spikes are showing past hop 6 the problem is outside of BT's Network.
Joseph90
Message 33 of 40
Your traceroute is showingthe high pings start withing BT'S network. Best contact them and show them the traceroute
h3x1e
Expert
Message 34 of 40
They don't care about information 😜 I'm in a battle trying to get them to even acknowledge the issue.
Joseph90
Message 35 of 40
I personally think its my smarthub or the 3rd Party BT is using to route my traffic. My connection stats are fine but im experiencing high latency. Totally frustrated
h3x1e
Expert
Message 36 of 40
We'd need to see traceroutes and maybe a PingLogger screenshot to try and add another case to the list. Will also help ruling out some stuff such as bad BT nodes or w/e.
The issue isn't really visible 24/7 for most people as it's Latency Variation and not constant high ping. Example being:
19ms > 19ms >19ms > 140ms >100ms > 60ms > 19ms >19ms etc etc
Can you check if Netflix will load for you, right at this moment, on a Laptop or something?
Could help.
Joseph90
Message 37 of 40
I don't watch netflix. I do notice however when searching the web sometimes websites will take a while to load, not all time but occasionally. My traceroutes to game servers are fine within BT's network but start reaching 100ms pings when it reaches the game servers. I contacted ea (i play madden)and provided them with the tracerouteand they said it looked like a routing problem. Ive contacted various other developers and playstation and i get told to contact my isp but bt says my connection is fine
Joseph90
Message 38 of 40
This was a traceroute i did a while ago when i contacted ea about the lag issue. I was with Virgin at the time but the results are the exact same with BT
Trace Statistics : traceroute to easo.ea.com (159.153.64.173), 30 hops max, 38 byte packets
1 10.161.188.1 (10.161.188.1) 10.000 ms 20.000 ms 10.000 ms
2 gate-core-2a-xe-702-0.network.virginmedia.net (80.0.144.101) 10.000 ms 10.000 ms 50.000 ms
3 * * *
4 * * *
5 86.85-254-62.static.virginmediabusiness.co.uk (62.254.85.86) 20.000 ms 20.000 ms 20.000 ms
6 213.46.175.250 (213.46.175.250) 20.000 ms 20.000 ms 30.000 ms
7 ae11.mpr2.lhr2.uk.zip.zayo.com (64.125.30.52) 20.000 ms 20.000 ms 30.000 ms
8 ae27.cs1.lhr11.uk.eth.zayo.com (64.125.30.236) 100.000 ms 90.000 ms 90.000 ms
9 * * *
10 ae4.cs1.dca2.us.eth.zayo.com (64.125.29.203) 100.000 ms 90.000 ms 100.000 ms
11 ae27.cr1.dca2.us.zip.zayo.com (64.125.30.247) 90.000 ms 90.000 ms 100.000 ms
12 ae22.er2.iad10.us.zip.zayo.com (64.125.29.121) 160.000 ms 200.000 ms 100.000 ms
13 64.125.199.190.t00673-02.above.net (64.125.199.190) 90.000 ms 90.000 ms 100.000 ms
14 159.153.92.98 (159.153.92.98) 100.000 ms 90.000 ms 90.000 ms
15 * * *
16 * * *
17 * * *
18 *
Joseph90
Message 39 of 40
Ea said it looked like a router problem
h3x1e
Expert
Message 40 of 40
would love to see an IPv4 traceroute while on BT
