Dieroff
Message 1 of 4
OpenReach Master Socket 5C
BT have recently provided me with a new landline/broadband connection to my new build home.  In this, the OpenReach Engineer fitted an OpenReach Master Socket 5C Mk 2 - it was all that he had left in his truck.
I want to fit a Mk 4 faceplate with ADSL inbuilt filter.
Will a MK 4 faceplace fit to my existing MK 2 base, or will I have to start from scratch
and purchase a MK4 faceplate c/w dedicated base?
3 REPLIES 3
Keith_Beddoe
Message 2 of 4
Re: OpenReach Master Socket 5C
@Dieroff
Just unclip the front, and clip in the replacement MK4 faceplate. You will probably have to buy both parts, but just use the faceplate.
Dieroff
Message 3 of 4
Thank you very much for your kind response.
I was hoping that it was as simple as you advise.
Keith_Beddoe
Message 4 of 4
That is the way it was designed, to make things simple. The only drawback is if the retaining clips break, so be careful.
