Message 1 of 2
Opening ports on home hub 4
I have just had an alarm fitted which has a remote monitoring app for my phone. The alarm is all set up but the app doesn't work as it says the box inset connected. The tech people said I need to open UDP ports 243 and 443 on my router.
i tried chat but the girl put me onto customer care and they had never come across this but did explain how to get into my hub manager. I've tried a couple if thing still but it doesn't work. Any suggestions?  Thanks
1 REPLY 1
Moderator
Moderator
Message 2 of 2
Re: Opening ports on home hub 4
Hi @Char2 and welcome.
I'm sorry you're having problems with openiong ports on the hub 4. Take a look at How do I set up port forwarding on my BT Hub? which help with this. Let me know how you get on.
Cheers
David
