Message 1 of 3
Openreach modem needed?
Hi,
I'm a disenchanted Complete Wifi user and, whilst I've decided to stick with BT as an ISP, I'm going to stop using the Smarthub 2 + discs and install something like Netgear Orbi. So, presumably I need to obtain an Openreach modem from somewhere to allow me to connect an alternative router. Am I correct and can someone tell me how to obtain what I need.
Thanks.
2 REPLIES 2
Message 2 of 3
Re: Openreach modem needed?
Yes, ebay
Message 3 of 3
Thanks, there's quite a few there. Not sure what to go for. The problem I'm trying to overcome is devices/apps that complain that they're not connected to the same network although clearly they are, i.e. one SSID. It seems to a problem that arises when a device is connected to one disc and an app on a laptop/tablet connected to the hub or another disc can't see it. It's a constant issue that I've never been able to resolve and I'm now hoping that another solution is better, i.e, Orbi. Trouble is I can't be sure...
