Message 1 of 1
Orbi RBk50 instead on Deco M9 Plus
Hi all,
I have changed from the Smart Hub 2 to a Vigor 130 and Feco M9 plus setup. However the M9’s fall over a lot and need resetting and I can’t get IPv6 to work, it throws me out of the system and needs a full reset every time I try and make a change. Therefore I’m thinking of changing to the Orbi 50, but does anyone know if it supports /56?
