bhamkum
Newbie
Message 1 of 7
Our BT network is using someone else's network - constantly dropping out
Our BT network is very slow and constantly dropping out. We were told to log into the BT Smart Hub manager and here we found that the name of the network we were connected to was different to the name of the hub. BT customer service have provided no solution to this problem, would appreciate any help on this matter.
6 REPLIES 6
gibbylinks
Message 2 of 7
Re: Our BT network is using someone else's network - constantly dropping out
The name of your network should be on the back of the hub labelled as SSID, working from memory because I'm not at home, but I'm sure the password is also there.
It should also be on a small "business card" that came with the hub.
If you are connecting to BT-FON then this is part of BT's network that is public and shared to all their customers, by their routers, and because it's shared it won't be fast and could have drop outs.
You can't really complain about it being slow if you aren't connected to the correct network.
Message 3 of 7
if you are in any doubt then press the recessed button on the back and hold for 20/30secs until lights flash and that should be hub back to factory setting like it just came out the box
JMB
Message 4 of 7
Windows PCs do usually go back to the previously used network when you switch them on (though you cannot guarantee it) but Android mobile phones always seem to connect to BT-FON by default and have to be manually connected to the correct network.
MB
Message 5 of 7
I have an Android phone and tablet and it is very rare for them to connect to BTWifi-Fon if I am in range of my home network and they do not need to be connected manually at anytime.
JMB
Message 6 of 7
My phone goes onto BT-Fon most times when I switch WiFi back on at home.
MB
Message 7 of 7
It is not a "default" setting as you have stated. It may be a problem on your phone.
If you are using the BTWifi app make sure you have ticked box in the app settings to automatically connect to your home hub when in range.
If that is selected you should go into the phones wireless network settings and "forget" any connections to BTWifi-Fon.
