EABowden
Message 1 of 3
PC gaming problem - Cannot load multiplayer servers since switching to Hub 6
We had wifi connectivity issues, so BT sent me a Hub 6 to replace the Hub 5. Since installing that, however, my son is unable to play his laptop games.
Either when we try to load a multiplayer server on a windows 10 laptop it says server not responding, specifically in Unturned
Or games like Roblox crash after five or ten minutes.
There seems to be a lot of chatter on the forums about this, but I can't find the specific answer. Some posts talk about setting up port forwarding and static IP addresses, but this is a bit beyond me. Why would I need to go into the router's advanced settings to make something work that was fine in the older router?
Help gratefully received
2 REPLIES 2
Moderator
Moderator
Message 2 of 3
Re: PC gaming problem - Cannot load multiplayer servers since switching to Hub 6
Hi @EABowden,
Have you tried setting up port forwarding on your Hub?
How do I set up port forwarding on my BT Hub?
PaddyB
Community ModeratorPaddyB
Show your appreciation!
Kudos”Kudos”
EABowden
Message 3 of 3
I've tried but it doesn't seem to have had any effect
