shoryard
Message 1 of 6
PPP password and it's relationship to security issues
Hi,
Just wondering if someone can clean a concern up for me.
I have just changed my old BT HomeHub3 and decided to go for a TP-Link router. When I was setting it up I had to enter the PPP username and PPP password. The PPP username I found out was 'bthomehub@btbroadband.com' which just seems to be a generic username? The PPP password I entered was the one I use to log into the BT website. Thinking that the password was a bit weak I changed the password on the BT website. I expected to have to change it on the TP Link router but I didn't as I could still connect to the internet.
Can someone explain what the PPP password is for, can I change the password - if so how, if the password is weak does it have any security issues?
5 REPLIES 5
Message 2 of 6
Re: PPP password and it's relationship to security issues
The PPP user name and password is just to authenticate your internet connection as a BT customer. This is in fact accomplished by authenticating against your telephone number, hence a generic user name and password for your router.
In fact a password isn't actually required, it is usually the router that insists on one, anything will do as it isn't used.
shoryard
Message 3 of 6
Thanks for clearing that up.
So, if I understand you correctly, there's no point for a complex password as no one else can use it unless they are using my phone line?
Message 4 of 6
most just use BT as the password if router needs one
Message 5 of 6
Correct, the password isn't actually being used, its just keeping the router happy. BT HH's don't require a password.
shoryard
Message 6 of 6
Thank you very much for the answer! Very kind of you!
