Message 11 of 13
Re: PPPoE credentials for BT Fibre 2 (FTTC)
No, the credentials are generic not account specific.
You don't need to set the vlan id, that is a modem function.
Message 12 of 13
I assume you have tried a different Ethernet cable between modem and router in case that is the problem.
Try 8.8.8.8 and 8.8.4.4 for DNS servers.
Does the Huawei modem work with the hub in FTTP mode?
Message 13 of 13
OK so removing the VLAN ID has given me a valid connection! I left the DNS servers as "auto" but it also works if I specify my preferred server (9.9.9.9).
Sharing my settings here for other Unifi users:
