mtissington
Message 1 of 2
PPPoE suddenly stopped working
I have a netgear modem/router configured in modem only mode connected to an asus router.
the assus is configured to use PPPoE and until a couple of weeks it was all working perfectly.
suddenly I can no longer connect using pppoe, NOTHING has changed with either the modem or router so I can ony assume that something has changed with BT ... what do I need to do to get PPPoE working again?
(there is nothing wrong with the connection, if I revert to using pppoA then I can get a connection with the modem but that establishes TWO layers of NAT which I'm trying to avoid)
Thanks.
1 REPLY 1
Message 2 of 2
Re: PPPoE suddenly stopped working
PPPoE is only used on infinity that could be your connection problem
