Message 11 of 37
Re: PRIVATE IP OUTSIDE OF PRIVATE DHCP SCOPE COMMUNICATING WITH MY LAN
Very likely if it's not the Gateway
Message 12 of 37
Broadband IP address: 81.136.55.xxx
Default gateway: 172.16.13.191
Primary DNS: 81.139.56.100
Secondary DNS: 81.139.57.100
Message 13 of 37
If you really want to determine if it is on your LAN, very carefully unplug the fibre cable from the ONT to disconnect from the internet and see if the address is still pingable. This is at your own risk.
If it is pingable with the fibre disconnected but not with the ONT depowered, it must be the address of the ONT.
Message 14 of 37
Be interesting to see the result of that.  The ONT is the other side of the router WAN interface so I would still not expect 192.168 to reach it.
Message 15 of 37
Thanks for the suggestion of unplugging the fibre cable from the ONT. Good idea!
I did this and pings timed out, so this IP MUST be outside of my LAN and not the ONT itself.
Message 16 of 37
What result do you get if you try trace root to the ip address?
Message 17 of 37
Have done a few trace routes and that IP doesn't show as a hop to external hosts either.
This private IP to me, looks like a private device within BT's network. I suspect a customer/client device with broadcast subnet.
Message 18 of 37
Yes, 172.16.13.191 is the BRAS, it can't be beyond that as it isn't routable.
Message 19 of 37
I get the same via a different BRAS.
Possibly the address of the device used to update/access BT Hubs throughout the network.
Message 20 of 37
I also get the same result but with a different BRAS
