Fatboyslick
Message 1 of 3
PS4 and Vita Remote Play Help with Home Hub 4
Hi
Please can someone provide me some laymens terms help so I can use my PS Vita to remotely connect to my PS4?
I can get it to connect on the same network but not when outside of the home.
The PS4 and Vita are linked and all the general settings are on, I think it is the Router settings I need to change.
My readings have told me a few options:
- Open Port Forwarding
- Static IP
- DMZ the PS4
These are pretty foreign to me so wondered if anyone can give me a guided hand who has done it before on HH4?
Thanks in advance
Tags (4)
2 REPLIES 2
Autograph
Message 2 of 3
Re: PS4 and Vita Remote Play Help with Home Hub 4
Firstly, both the PS4 and Vita requires a good connection. I heard both should receive above 3 upload, and a ping below 30ms. (Don't take my word for it). I have a Home hub 5 which I think is pretty much the same, buy the Home Hub 4 uses an Open reach modem. So firstly, what you want to do is to give your PS4 a static IP. Just some other stuff I'd say if your using WiFi on PS4, keep it at a high signal strength, of around 95% above, but that's if your unable to wire it. If you can wire it then I'll recommend you do that.
To set a static IP watch this video.
https://www.youtube.com/watch?v=ogTkE4Hr7ls
So after you set a static IP on your PS4. Head to a laptop or computer and go on to a browser and type 192.168.1.254 (I think that's HH4 gateway). Watch this video.
https://www.youtube.com/watch?v=Ta79qi0Uxzk
If you do get stuck somewhere message me back. Hopefully, I or someone else will assist you.
Fatboyslick
Message 3 of 3
Hi
Sadly this just didnt work for me - or atleast I'm not clever enough to manage the Router settings
