RHJVD22
Message 21 of 31
Re: Packet Loss Constantly...
h3x1e
Message 22 of 31
As you can see, very similar issues, even though you're not getting as high spikes as I am. Same kind of packet loss at the same nodes.
RHJVD22
Message 23 of 31
So do you have a fix because this is making me loose my mind Lmao
h3x1e
Message 24 of 31
Nope, there is no fix as of right now. I'm working to try and get someone at BT to try and get this in the hands of the network engineers to fix whatever needs fixing.
RHJVD22
Message 25 of 31
Have you tried directly plugging into the hub
h3x1e
Message 26 of 31
I'm always hard wired into a hub, I never game on WiFi since it causes it's own issues. The only thing on WiFi in my house are phones and tablets with I don't game on.
If you are connected via WiFi though and those tests were via WiFi I would test while hard wired into the hub.
RHJVD22
Message 27 of 31
If im directly plugged into the hub i get no packetloss but right now im directly plugged into my wifi disc which is connected to my hub.
h3x1e
Message 28 of 31
There are so many things with WiFi that can cause Packetloss, from interference from a faulty electrical device to the thickness of walls so yeah, that's why I would never recommend gaming via WiFi.
RHJVD22
Message 29 of 31
True does anyone have a fix who looks at this post...?
RHJVD22
Message 30 of 31
So tempting to move to another broadband provider all BT has done has caused problems and not fixing them. I’ve done everything I can on my side literally. Couple of weeks ago it was fine then it got a little bit bad now it’s unbearable. Literally no fixes.
