Message 21 of 67
Re: Pages of TR69 ConnectionRequest Failed
The OP has a third party router front ended by the HH6 (message 8). Smiley Wink
dfects
Message 22 of 67
If I picked up a HG612, I'd be using it with my Asus AC66U (over PPOE) like I used to with my draytek vigor on adsl 🙂 Will probably pick one up soon... was really hoping the home hub would just do its job the best it could as the more numbers there are to monitor the more OCD I get about this kind of thing 😞
Thanks for the info though!
smf22
Recognised Expert
Message 23 of 67
Missed that. I think a £10 or so investment to someone on the well known auction site is well called for.
Message 24 of 67
Unfortunately I think they are a little bit more than that these days, people are catching on to the value of them.
dfects
Message 25 of 67
Yeah looking at about £30-40 for one. Still not a terrible price though. Shame they don't just allow you to see more error information on the hh6. At least they could fix the bug showing the speed in kbps instead of mbps!
Message 26 of 67
Even if it did, its still a bodge trying to use a HH in front of another router, much better to use a true modem.
Don't pay a premium for an unlocked one, its child's play to unlock the Huawei. Soldering iron job for the ECI though.
dfects
Message 27 of 67
True, I was suprised it worked so well. Even upnp seems to function correctly! vpn in and out not a problem too.
shamus1
Expert
Message 28 of 67
i too have been having tr69 connection request failed for the last 2 days and running hub 6 with SG4B1000223E firmware.im wondering if its a problem with bt servers or something ?
Distinguished Expert
Message 29 of 67
Yes, mine updated to 223E overnight.
There are no problems, no immediately apparent changes other than BT wifi is now active.
Smartphone initially connected to "BT wifi with fon" but quickly reverted to HH6 wireless, which is set as default.
However TR69 connection request "failed" persists.
Will try a factory reset - but not today - as it's not always a 5 minute task! Smiley Indifferent
Was your TR69 problem there before the 223E update, or did it just start in the past 2, 3 days?
It may give a clue....
mortisia
Newbie
Message 30 of 67
Also have pages of this and intermittent disconnections/sluggish speeds over the last 2-3wks gradually getting worse
Any resolution for this that doesnt require a degree in network engineering?
Just to add my hub 6 updated to latest firmware on 27/11 but I have errors from before that too
13:51:43, 26 Nov.
ppp1:TR69 ConnectionRequest: processing request from ACS
13:40:17, 26 Nov.
BR_LAN:LAN Neighbor Discovery : Host fe80::ce1:bee2:1706:42f0 is set inactive
12:12:40, 29 Nov.
ppp1:TR69 ConnectionRequest Failed
12:12:40, 29 Nov.
12:12:40, 29 Nov.
12:12:40, 29 Nov.
12:12:39, 29 Nov.
12:12:39, 29 Nov.
12:12:39, 29 Nov.
12:12:39, 29 Nov.
12:12:39, 29 Nov.
12:12:39, 29 Nov.
12:12:38, 29 Nov.
12:12:38, 29 Nov.
12:11:36, 29 Nov.
BR_LAN:LAN Neighbor Discovery : Host fe80::186a:1540:263c:7909 is set inactive
12:11:24, 29 Nov.
wl1:Device <B4:E1:C4:1A:46:6C> was disconnected on SSID (Device/WiFi/SSIDs/SSID[WL_PRIV2G])
12:11:12, 29 Nov.
12:11:12, 29 Nov.
12:11:11, 29 Nov.
12:11:11, 29 Nov.
12:10:50, 29 Nov.
:HTTP UserBasic login from 192.168.1.137 successfully
12:10:24, 29 Nov.
BR_LAN:LAN Neighbor Discovery : Host fe80::186a:1540:263c:7909 is set active
12:08:40, 29 Nov.
ppp1:TR69 connectivity to (pbthdm.bt.mo) has been closed
12:08:39, 29 Nov.
ppp1:TR69 connectivity to (pbthdm.bt.mo) has been initiated
12:08:39, 29 Nov.
InformResponse:TR69 receiving X����f��l���|����� message
12:08:39, 29 Nov.
ppp1:TR69 event found : 4 VALUE CHANGE
12:08:38, 29 Nov.
ppp1:TR69 sending Inform message
12:08:37, 29 Nov.
12:08:36, 29 Nov.
12:08:36, 29 Nov.
ppp1:TR69 creating new session with ACS
12:08:20, 29 Nov.
12:08:19, 29 Nov.
:TR69 sending SetParameterValuesResponse message
12:08:19, 29 Nov.
SetParameterValues:TR69 receiving ���<�{u_�B;&t;)� message
12:08:19, 29 Nov.
