Message 1 of 6
Paramount+ Micro Buffering
I'm having issues with very brief pauses in the Paramount+ app on my LG TV, the pause is imperceptible for the most part but the app flicks up the play icon centre screen when it happens, which is about every 3 minutes.  I've tried all the obvious stuff (reinstall app, power cycle everything) with no luck.  I was wondering if there might be a routing issue that I can add an entry into the router routing tables for or something.
Anyone have any ideas?
5 REPLIES 5
Message 2 of 6
Re: Paramount+ Micro Buffering
HI @Brother52
Is your TV connected via WiFi or it is connected using an Ethernet cable (cat 5e or above)?
Ali
Message 3 of 6
Hi it’s ether net cat 5
Message 4 of 6
OK, thanks @Brother52
Could you try another ethernet cable, just to see if it makes a difference please?
Chris
Message 5 of 6
Will do but all other 4K streaming apps work fine
Message 6 of 6
Hi - I get this to a lesser degree on my box and smart TV.  I believe it must be something on Paramounts end though as I tested tethering my 5G signal (which is less speed than my full fibre internet) to my smart TV and the issue remained
