pangit
Message 1 of 3
Phone connecting to FON not Homehub
I get really frustrated when I move from one room to another in my home, but instead of connecting directly to my Homehub, the phone connects to BTWifi-with-FON. I have read on here that I should simply go into my wireless settings and click on forget network.....yes, this does work, but why should I have to do it....there is no problem with signal strength from the hub, I can be less than 5 metres from it in the same room, and it connects to FON.
Tags (3)
2 REPLIES 2
licquorice
Message 2 of 3
Re: Phone connecting to FON not Homehub
The hub is transmitting 2 signals of equal strength, how is BT responsible for which signal your phone chooses to connect to?
PaddyB
Moderator
Moderator
Message 3 of 3
