NeilO
Moderator
Moderator
Message 11 of 15
Re: Phone interfering with the wifi....any solutions?
@tuitui22 if you connect to the test socket and the hub continues to reset when the phone rings then it would likely be problem with the line.
Devon_Dave
Distinguished Guru
Message 12 of 15
Sounds like your IT "expert" has no idea what he is on about.
Suggest you follow John and Neil's idea of checking for noise on the copper landline.
(If I have helped you in any way please click the thumbs up. Thank You)
If I have solved your Issue please click the "Mark as accepted solution" button.
tuitui22
Message 13 of 15
Thanks these are all great solutions!  I'll try the things you suggest.
Thanks a lot!!!
(The guy I mentioned this to and who works in IT  lives in Israel. Maybe they have a more modern system over there, I don't know! He did seems surprized that the telephone line was involved)
NeilO
Moderator
Moderator
Message 14 of 15
@tuitui22 This type of problem wouldn't affect a full fibre optic line so that's where the misunderstanding may have originated?  If you could do the test socket check and also do the quiet line check and post back the results it will help us understand if the problem is on the network/line or within your home set up.
tuitui22
Message 15 of 15
Hi ! I was re-reading the post and I don't understand what a test socket is. Do I have one? I' m not sure either what a hub is!
