h3x1e
Message 21 of 29
Re: Ping Jitter from 20ms to 250ms every 5 seconds on Fibre Broadband.
You'll see plenty of posts about this issue on these forums, unfortunately there is no KNOWN fix for this right now. I also have a BT Wholesale Engineer coming out tomorrow to look at my problem (the 10th Engineer)
The issue lies within BT's network, there's nothing Openreach can do about it.
If you boot up PingPlotter you'll be able to see the nodes where the ping spikes start happening.
I'm gonna guess it starts on node 3 or 4, and im gonna guess those nodes will be 31.55.186.176 and 31.55.186.177.
These two nodes are suspect in everyone traceroute results.
matthewuncle
Message 22 of 29
Thank you.  I'll give that a go.
Interestingly, for me, turning down the Netflix stream settings to low has helped magnificently.  Shouldn't need to do it though.
h3x1e
Message 23 of 29
Do you ever get issues loading Netflix on a PC?
I noticed on a number of occasions that my Netflix wouldnt load on any browser on PC, so I did a ping at the same time (with a Twitch 1080p 60fps around 1MB/s bandwidth) stream running too and my ping was perfectly fine. I'm on a 32Mbit connection so more than enough bandwidth to handle 2 streams and a game or two.
matthewuncle
Message 24 of 29
I ran pingplotter for 10 minutes.  The first two spikes were when Netflix was running at low quality.  I changed the settings to auto at 21:47 and you can see what a difference it made.   75% of packets lost on hop 3.  Is that you were referring to?
Any update from your engineer today?
h3x1e
Message 25 of 29
Na Engineer didn't even come to the house, doubt he / she even went o the exchange.
No resolution today, called them and they're escalating the issue to their "Offline team" to see what they can do.
h3x1e
Message 26 of 29
The nodes at 31.55.185.XXX are the problem here I think. Over all the Pings / Treaceroutes I've seen they all have those nodes in common.
itani
Message 27 of 29
This problem started in december for me and an engineer came round and said theres nothing wrong with my connection 😂 and so did BT. Was able to do everything but game online.
Anyway i was lucky i moved house and isp in march and that fixed my problem.
lolowalsh
Message 28 of 29
@itani which provider did you move to ? I'm having ping spikes even when the network is idle 😂😂. And they seem to happen every day at the same time during the day.
I just did a speed test and it was 1 down/ 3 up and a ping of 388.
itani
Message 29 of 29
Hyperoptic
