Venomx
Expert
Message 1 of 5
Poor Wi-Fi Speeds
Got a 5Ghz lan card in a brand new computer and connected to the 5Ghz network
Sync speed is 75mb down and 20mb up
I used to get about 70/20 on speed tests on my old computer, however on my new PC im only getting 35 down and 3 up
Signal strength is excellent
If I hard wire I do get about 70/20
4 REPLIES 4
Message 2 of 5
Re: Poor Wi-Fi Speeds
If you haven't already done it, make sure you turn off "smart setup" on the Homehub.
See link how to do that.
http://bt.custhelp.com/app/answers/detail/a_id/44328/~/what-is-smart-setup-on-the-bt-hub%3F-how-can-...
You should also make sure that your card's drivers are the most up to date via the card manufacturer's web site rather than using Windows drivers.
Venomx
Expert
Message 3 of 5
Can't get any drivers to work on Linux, it did come with a CD but i've no CD drive.
I am now trying wired and getting 67/18. My sync speed is 74/20 so shouldn't i theoretically be getting full speed wired ?
Message 4 of 5
If the Network Card came with CD and there are Linux drivers on that you should be able to get them as a download from the card manufacturer.
If not you can get get portable CD drives for about £10 but you may have a driver problem with them due to using Linux.
Venomx
Expert
Message 5 of 5
Ok i already have the drivers on my linux machine.
I heard it is something to do with the full duplex settings ?
Another question, if im hard wired why am i not getting the full speeds ?
