Hi
Is there anything I can do to impove the WiFi connection around the house,wired is fine but I cannot use WiFi upstairs is just keeps disconnecting, I have tried with separate bands and even tried different channels but it is just useless even 1 room away, I did the online chat but they just told me my connection was fine which I know it is, does anyone know if I am missing a setting somewhere please.
I though you were using a different router?
https://community.bt.com/t5/YouView-from-BT/BT-TV-on-3rd-party-router/m-p/1773983#M39978
If not, then something like this works quite well.
https://www.shop.bt.com/products/bt-mini-wi-fi-home-hotspot-600-kit-084288-BVFF.html
Can often be obtained cheaper elsewhere.
Maybe change to complete wifi package and get the discs to cover you home with wifi guarantee
No m8 I am using the BT hub I had a Netgear but it packed in but Im thinking I may need to buy another router I just cant get the Wifi on the hub to work properly.
Its possible that you have a faulty home hub, so you could ask for a replacement if you are still in a contract.
The nearest third party dual band router would be something like
TP-Link AC1200 Wireless Dual Band VDSL/ADSL about £67
https://www.tp-link.com/uk/products/details/cat-15_Archer-VR400.html#specifications
That works with all BT services, including BT YouView.
There is a cheaper single band model as well.
