joelsweb
Newbie
Message 1 of 2
Port Forwarding Custom Ports Home Hub 3
I'm trying to port forward some custom ports, so I create a new application, and that seems to work fine.
When I try to assign it, I select my application from the list, however, when I select a device, it appears to append an existing application on to the end of my current application in the dropdown.
E.g. CustomApp becomes CustomAppPOP3
Clicking assign then assigns POP3 to my device, rather than CustomApp.
Any ideas why this might be happening?
1 REPLY 1
Message 2 of 2
Re: Port Forwarding Custom Ports Home Hub 3
There is a worked example of port forwarding on the link below.
It refers to a VPN, but the steps you need to take are the same.
Port forwarding example
