JDodger
Newbie
Message 1 of 3
Port Forwarding
So my family just switched over to bt from Sky, I had port forwarding set up on sky before so i have a rough idea about what I'm doing. I went through the process of port forwarding myself since the interface is simple enough to understand, I created two new applications: Minecraft (25565) and Terraria (7777). I assigned these applications to my static IP I set on my computer on this connection (192.168.1.151). I applied all the changes, rebooted the router, aaaaannd.... the ports aren't open. I've done some googling afterwards, read through some other posts of people having problems but nothing has helped me, not even disabling UPnP. I also have a friend on BT who couldn't get his port forwarding working. I'm using the BT Home Hub 4 Type A. Is there something I'm doing wrong or is it a problem I can't help?
Thanks in advance,
Jamie
2 REPLIES 2
Message 2 of 3
Re: Port Forwarding
This page may help.
Port forwarding problems
JDodger
Newbie
Message 3 of 3
Re: Port Forwarding
No I've seen that link on so many other threads and it doesn't help I'm afraid.
