Ryan_Clarke
Newbie
Message 1 of 2
Port Forwarding
Recently, we upgraded to BTHub3 from the old BT Homehub 2 which works happily worked, but, Me being a gamer, decided to set up my own Server for Grand Theft Auto Multiplayer, which, before worked fine being hosted off my router, but after the upgrade to the Hub3 I found that I could no longer host my Test server (I only use it to test my scripts before placing it on my Decicated box). I tried changing the ports about, I tried 9987, my old port, I tried 7777 7778 9988 and loads more, but I found it wasn't working. I started asking around and no one seemed to know what needed to be done differently so... for me, and the many others, Can you, either show us a tutorial on how to Port Forward Properly, or do a DETAILED Step-by-Step guide on how to do it.
Many Thanks
-Ryan
Tags (3)
1 REPLY 1
Message 2 of 2
Re: Port Forwarding
There is a detailed guide on this page.
Port forwarding problems
