Message 11 of 13
Re: Port forwarding Behaviour?
HI
Previous Provider was K-Com. had been for years. Primary ip was 192.168.1.1.  I was unaware when the SH2 was installed that the Port fowarding could be problematic?. What does intrige me is the fact that I can "port forward" what is an "onvif" device. I can see and operate it from my ios devices too?. But the other cam`s on the same system are unavailable?. And none of the devices have changed or "lost" their static ip`s?. It` a real "bummer", as the speed increase is noticable on the rest of the Network. I`m not even sure the old Router can be repurposed, although when purchased it was slated as being "fibre" compatable. (TP Link AC 2100). AND of course the Digital Phones are linked to the bt hub.
Pete
Message 12 of 13
Are you sure you changed the gateway address on the devices to 192.168.1.254 as @countrypaul suggested.
Message 13 of 13
Dohhhh!!!!.
Well it worked for 2 out of 6 cams. I will tackle the others tomorrow with fresh eyes. Thanks to all concerned
Pete
