tommytastic
Newbie
Message 1 of 5
Port forwarding conflict with applicaton ssh
Hi,
I have 2 machines in my home network that I want to be able to ssh to from externally using different ports, 22 and 2022. Both forwarders need to forward to port 22 on the 2 machines. I only seem to be able to establish one forwarder. The second one complains that it conflicts with the first. It seems like it can't handle forwarding to the same port despite it being on a different server. Is this a known bug? Is there a workaround?
Thanks, Tom
4 REPLIES 4
Message 2 of 5
Re: Port forwarding conflict with applicaton ssh
Which hub are yyou using if it is the home hub 3 there are many posts on the subject I suggestyou try theforum search as it will give you the answers you need
Message 3 of 5
The NAT within the home hub can only map to one port of the same number, irrespective of the device, its just the way it works.
I am not sure which routers would be capable of this.
tommytastic
Newbie
Message 4 of 5
Shame, my old o2 router could handle it fine. I wonder if it's possible to use a different router with BT Infinity?
Message 5 of 5
