matthiasa4
Message 1 of 7
Port forwarding on BT Smart Hub 2
I have tried setting up port-forwarding and DDNS on my BT Smart Hub 2. I was successful for 2 ports, but am struggling to get port 80 working as this is serving the BT Smart Hub 2 Manager page (not what I intend to do).
Any help or settings that I have missed to set this up properly?
Thanks!
6 REPLIES 6
licquorice
Message 2 of 7
Re: Port forwarding on BT Smart Hub 2
I guess you are accessing port80 from within your LAN rather than accessing via your public IP address using 4G rather than your own wifi.
matthiasa4
Message 3 of 7
Since I saw the other topics regarding NAT loopback, I made sure I tried on my mobile connection as well. Same problem though, while other ports function as they should.
licquorice
Message 4 of 7
What is the actual problem you are experiencing, the hub manager is not accessible via your public IP address so the fact it uses port 80 shouldn't be a problem. You could try a factory reset of the hub and start again.
matthiasa4
Message 5 of 7
Found the issue.  Didn't open 443 although the service is HTTPS 🙂
licquorice
Message 6 of 7
Thanks for the update.
You might be interested in my discoveries in message 16 of this  thread regarding port forwarding on the SH2.
matthiasa4
Message 7 of 7
Brilliant! It's starting to add up. Thanks a lot for your kind help 🙂
