simw
Message 1 of 6
Port forwarding on Home Hub 4 for CCTV system.
I am trying to view my CCTV system's cameras over the Internet, and I've read I need to set up Port forwarding, but I'm not sure how many ports I have to open and if they are TCP or UCP ?
5 REPLIES 5
Message 2 of 6
Re: Port forwarding on Home Hub 4 for CCTV system.
Look at this guide first.
Port forwarding problems
Then see if there is an example for your camera om this page.
CCTV and IP cameras - port forwarding
If not, then can you say which IP camera you have so that help can be offered.
simw
Message 3 of 6
I also seem to have the problem, that although I have connected the system to my BT home hub via Ethernet cab. The device doesn't appear, in the Home network map, in the hub manager. It just shows the speed of the connection, but no details or IP address.
Message 4 of 6
I would not rely on the home network map. Follow my guidance and remember to set the IP address on the camera itself.
General help here Port forwarding problems
I have a number of Foscam IP cameras which work just fine.
simw
Message 5 of 6
I have finally got the CCTV to connect to the router, and have the port forwarding set . I can log on to the video feed from the CCTV locally via WiFi on my phone, however, when I switch off my wifi and try to connect to CCTV, via internet , using the 4g signal on my phone, I just get the message that the Server is unavailable. Would there be anything else on the router,blocking the CCTV camera access to the Internet ?
Is there anyway I can test that the ports are open to the Internet ?
It works find on local home  network.
Message 6 of 6
If you read my page on port forwarding, it will tell you how to check.
http://forumhelp.dyndns.info/networking/portforward.html
Remember, you will need a DDNS provider.
