mitchd2100
Message 1 of 1
Port forwarding problems with Home Hub 4.
I will try and explain this as best as I can, here goes...
These pics will show everything set up the way it should be (I think) for the Xbox360...
and...
Now the problem is with this log...
I'm really hoping someone with router knowledge can explain what this means and maybe I will find out what is causing me to get disconnected intermitently while playing online...
Oh, and here is a pic of my Firmware, just to see if that helps in any way...
