Message 1 of 2
Port forwarding query HH 4
Hi
Running out of ideas!
I have  set up FTP site on my window 10 PC. I have also set up Port forwarding for FTP on on HH 4, FTP port on Mcaffe has been enabled.
I can access the site on the LAN. I have checked the port for FTP is open using my public Ip address. But when I try and access the ftp site using my public Ip address I get the following comment in the firewall event log :-
IN: ACCEPT [57] Connection closed (Port Forwarding: TCP [xxx.xxx.xxx.xxx]:21 <-​-​> [xxx.xxx.xxx.xxx]:21 -​ -​ -​ [xxx.xxx.xxx.xxx]:1024 CLOSED/SYN_SENT FTP child: No local_dev NAPT).
Thanks in anticipation
1 REPLY 1
Message 2 of 2
Re: Port forwarding query HH 4
How are you trying to access it via your public IP, if you are trying to access it via your own wifi it won't work. You need to access it from 4G or somewhere else. The home hubs don't support NAT loopback.
