Jaysnp101
Message 101 of 127
Re: Port forwarding.
Yeah I guess a traceroute isn't gonna help.
Am I still able to request a DLM reset or does that require a engineer?
Thinking maybe my connection is bad because of interleaving but still wouldn't explain the ports not opening 🤔
Jaysnp101
Message 102 of 127
This is another thing that happens occasionally.
Below I've posted 2 images with Upnp enabled but nothing else.
Playstation is 192.168.1.114
Galaxy S9 is 192.168.1.11
These are automatic ports forwarded by playstation or gamin developer.
You'll see that have opened 2 ports but to the wrong ip address. Top one even says 192.xxx.xxx.114 then shows 192.xxx.xxx.11 underneath.
Jaysnp101
Message 103 of 127
Jaysnp101
Message 104 of 127
Jaysnp101
Message 105 of 127
@licquorice , @TimCurtis , @Anonymous
Any advice on the above, surely something isn't right.
Anonymous
Not applicable
Message 106 of 127
As I said before, I don't recognise that app and I don't understand the format. The MyBT App I have looks nothing like that and I can't find anything that does
Try taking a screenshot using a browser instead
Jaysnp101
Message 107 of 127
@Anonymous
This is just using the browser on my phone on the smart hub interface.
I have got the MyBT app but your not able to change settings and stuff to your router through that.
Jaysnp101
Message 108 of 127
licquorice
Message 109 of 127
192.168.1.11 is outside of the DHCP range of the hub, have you given the galaxy a static address?
Jaysnp101
Message 110 of 127
Hi
Yes I gave it a static ip, would this effect the upnp giving it port forwards instead of the correct device 192.168.1.114?
