Angie3
Message 1 of 3
Port forwarding .
Hi, can anyone help me please.
I am trying to open ports 25,000 and port 443 on my home hub 5 and it’s asking me for a game or device name and I am unsure of what to put in the box.  I have to go to advanced or additional settings page.
I am trying to connect my wireless alarm system.
I have tried to use the system Id
i have tried to use the name pyronix
I have tried to use Home Control+ (App name)
None of them have worked.
also it asks for protocol? port range and translate to - I used 25000 in all 4 boxes on one line - clicked apply
then 443 in all 4 boxes on second line and clicked apply
but none of it worked.
Has anyone got any ideas I can try please
Thank you.
2 REPLIES 2
Message 2 of 3
Re: Port forwarding .
See http://bt.custhelp.com/app/answers/detail/a_id/8790/~/how-do-i-set-up-port-forwarding-on-my-bt-hub%3...
You need to first of all create 2 new 'games', it doesn't matter what you call them, its just a label. Then allocate the ports you need to the device after you have created the new 'games'. Select 'any' for protocol and the same port number in all 4 boxes for each of the rules. Give your device a static IP address on the device itself if you can, or use address reservation on the hub if not.
Angie3
Message 3 of 3
Thank you very much.  Really appreciate your advice.  I was totally stuck.
thanks again.
