I'm not a gamer or use a SH2, but I had a port forward issue recently and it was caused by upnp being on and another server had taken ports. I disabled upnp and forwarded manually and all was OK. Worth a try.
Thanks for the help @pxr5 , I already have upnp disabled although I have tried it with and without.
I was thinking maybe the ports are already being used by another application but is that even possible.
I do have some wireless cctv cameras set up that possibly use GVCP protocol if anyones aware of this?
I also am aware that several gaming developers have started using this protocol recently due to how easy it is to adapt.
Once again the standard disclaimer, I'm not a gamer......... (AKA get out of jail free card).
A couple of websites that may be of use to you
4. Forwarding ports, or opening ports, in your router points all traffic coming in on certain ports to a specific internal IP address. To get a connection with NAT Type 2, you will want to forward the following ports to the IP address of your PS4:
TCP: 80, 443, 1935, 3478-3480
UDP: 3478-3479"
And
"Are you experiencing PS4 network problems? Here is a quick guide on how to change your PS4 NAT type and fix common errors."
https://www.denofgeek.com/games/how-to-change-nat-type-on-ps4/
You stated a few posts ago that it was wired , is that direct , through a switch(s) or over Powerline adapters.
Also running a test against speedtest.net what speeds and ping do you get?
And finally what other bandwith using devices might be connected?
@Anonymous
Thanks for the links you sent, ill try opening the list of ports tonight that are specific to the playstation to see if that helps but I think I have done so before.
Correct me if I'm wrong but I think the best NAT you can get is type 2 (moderate) when using a bt smart hub as its router/modem combo. Only way I can get nat type 1 is put another router i have into bridge mode and connect through pppoe.
I connect straight into router from playstation using ethernet.
Ill check stats tonight but usually 73/18 with ping about 20ms so ok i think.
Not really any other huge bandwidth users to be honest, occasionally netflix but I try to play when other half goes to bed. I did mention I had the cctv cameras but they work on motion detection so idle most of the time.
@Jaysnp101wrote:@Anonymous
I wish I could advise on that but you probably know more on the subject than I do, it does sound reasonable though.
Giving up with this banter Internet, everyone else enjoying their Friday evening and I'm off to lag/delay city.
Says I've got 20ms ping, feels like 700ms
I'm in much the same position as @Anonymous here I'm afraid.
One thing you could try perhaps is picking up a TP-Link 9970 modem/router for around £35 and trying that ,maybe that'll give a clue as to where the problem might be.
Hi @TimCurtis I have already got this router, I've just set it up so is there any settings you could suggest using or leaving alone. I've done a factory reset on it so gonna set up port forwarding first.
No luck with the NAT type?
