Jay_p911
Newbie
Message 1 of 2
Port priority
Hi is there any way to prioritise which ethanet port get the most signle on a home hub 3.
I have two pc's connected via ethanet cables to port 1 and 2. Want to give priority to port 1 the port 2 then wifi if all are in use at the same time.
Any help would be gratefully recieved
Tags (2)
1 REPLY 1
Message 2 of 2
Re: Port priority
Its not possible on the HH3, you would have to use an separate managed Ethernet switch, and wireless access point, which would be connected to this switch.
The other alternative would be to use a different router.
