tomcatuk
Message 1 of 3
Ports... my first post for help be gentle.... :-)
UDP port: 46100,46110,46112,46114,46120,46122
Using plug N play and they appear in the router when running the program, but sometimes they work other times they don't its for running some amateur radio software called Wires-X, sort of voip type thing the program has a port checker built in and 9 times out of 10 it works but then you load up the program another time and they simply refuse, all I am being told is that "it's your internet" by the makers of the software, but just wondered if BT do actually block any ports becoming a right pain....
I have even tried entering the ports manually and again it works, then you try it again and the same problem...
How can I tell if these ports are actually open, anyone offer advice?
Thanks in advance
2 REPLIES 2
RobbieBaron
Message 2 of 3
Re: Ports... my first post for help be gentle.... :-)
What does ShieldsUP! report the status of your ports when you use its User-Specified Custom Port Probe ?
tomcatuk
Message 3 of 3
Hi thanks for the reply ok tried a probe of all those ports and they report Stealth, but this only does a TCP probe I am using UDP on these ports (sorry don't really have a clue but would that make a difference)
I have run the program this morning and its working perfectly......
The program has a built in port checker and says they are all fine....
regards...
