Davewm1
Message 1 of 16
Printer not found
Hello all.
I’ve  come on to ask for support as the Samaritans is engaged.
I have a envy 4520 all-in-one printer. It’s been running perfectly well for a couple of years, no problems.
Yesterday I was unable to print from my Acer laptop.
I’ve tried every fix suggested by HP PrintDoctor and it still will not print.
For information it will print from multiple other devices ie: iPad, iPhones etc.
I’ve also tried to print from my wife’s laptop and that doesn’t work either. Both laptops are operating on Windows 10.
On both laptops a message comes up to say:-
Connection to the internet was not found or has been lost.
Can anyone please help?
Kind regards
David
15 REPLIES 15
Anonymous
Not applicable
Message 2 of 16
Re: Printer not found
Try restarting your PCs' or resetting the network from the control panel.
It's easy and convenient to put a Windows 10 PC into Sleep or Hibernate mode but Network errors can survive those restarts, they can't survive a full shutdown and restarts
Keith_Beddoe
Message 3 of 16
@Davewm1
Which BT Home Hub are you using?
Davewm1
Message 4 of 16
Hi there. It’s a smart hub 2
Keith_Beddoe
Message 5 of 16
Anonymous
Not applicable
Message 6 of 16
Can you see other local network devices in windows explorer (e.g. each others laptops)?
Can you access the internet?
If No for Q1 and Yes for Q2, open network settings and check that the Private radio button is selected (see below)
Davewm1
Message 7 of 16
Thanks for your reply.
I’ve tried the factory reset.
Please forgive for asking a daft question but with the second part of the suggestion am I supposed to turn off the smart setup and leave it off?
Regards
David
licquorice
Message 8 of 16
Davewm1
Message 9 of 16
I’ve now tried this with setting smart switch to off.
Unfortunately this didn’t work.
If you have anymore thoughts I’d be happy to try them. For info I tried to use the scanner function and this worked. I saved the document and printed it off successfully. But if I try to print anything else it just keeps repeating “printer not found “
Kind regards
David
TimCurtis
Guru
Message 10 of 16
@Davewm1
You could perhaps try removing the printer on the Windows devices and reinstalling it in case anything has got confused/corrupted.
