Newbie
Message 1 of 5
Problem accessing a secure website
Hello,
Via BT, I'm unable to access https://www.bdtkd.co.uk . Depending on browser used, I either get a friendly BT message saying site could be malicious, or a "SSL_ERROR_NO_CYPHER_OVERLAP' error.
If I connect to a VPN I can access web site fine. I've checked the SSL certificate an it appears to be in order.
I contacted the owner of the website and they say it's a know issue with BT customers.
Any ideas how I can report this to BT and ask them to investigate?
Thanks,
4 REPLIES 4
Expert
Message 2 of 5
Re: Problem accessing a secure website
Hi @jamiefc
It's loading okay for me using Edge. You could try Google DNS settings, do you have Parental Controls turned on?
Newbie
Message 3 of 5
Hi
Yes, just noticed that changing DNS settings (google, or opendns) and site works.
So it's BT's DNS that's causing the problem it appears.
Jamie
Newbie
Message 4 of 5
I dont' have parential controls enabled.
However "bt web protect" was enabled, so will disable that and see if it makes a difference.
Newbie
Message 5 of 5
I disabled BT Web Protect and website works ok now. Thanks.
