mandatrev
Message 1 of 2
Problem with connecting Seiki Smart Tv with Hub 6
We have a Seiki Smart Tv but it wont let the internet through so that youtube etc can be used. Under the portforwarding page of the smart hub, all devices have a green tick but not this tv. and on the my network page, no data is moving in or out of the device.
Have tried the turning off of the smart setup and changing the parental controls but nothing will allow in the internet in.
any other ideas out there would be appreciated.
1 REPLY 1
Message 2 of 2
Re: Problem with connecting Seiki Smart Tv with Hub 6
You do not have to user port forwarding to connect a smart TV.
Connect the TV using an Ethernet cable or broadband extenders.
http://www.shop.bt.com/mini-sites/connected-home/
