Showing results forΒ
Search instead forΒ
Did you mean:Β
Zepzod
Message 1 of 29
Problems connecting Swann DVR to Smart hub.
Could anyone tell me how to set up my Swann dvr on my Smart hub, everything worked fine previously with my Netgear router but I now need to use the Smart hub to access my BT tv channels. I use a dynamic dns service no ip .com .
is this possible with the new Smart hub ?
    Many thanks.
28 REPLIES 28
Message 2 of 29
Re: Problems connecting Swann DVR to Smart hub.
Yes, should be. Have you tried enabling IGMP snooping on the Netgear though?
Zepzod
Message 3 of 29
No problems on the Netgear worked fine.
Message 4 of 29
..........so that you can use the Netgear to receive BT TV.
Zepzod
Message 5 of 29
Ok where will I find this setting ?
Message 6 of 29
Post not needed now
Message 7 of 29
No idea, I haven't got a Netgear. Try the manual? Enabling IGMP snooping should allow you to use the Netgear with BTTV.
I would stick to the Netgear if you can get it to work.
Zepzod
Message 8 of 29
Sorted now the Netgear works with BT TV πŸ‘
Message 9 of 29
Smiley Happy
Zepzod
Message 10 of 29
Can I still use the no ip.com with the Smart hub ?
