MaccaHM
Message 1 of 6
Problems with Wireless
Hello,
These are the results from my Broadband Speed Test from earlier which I ran through an Ethernet cable (wired):
http://www.speedtest.net/my-result/2902485979
This is the speed which we SHOULD be receiving.
However this is the result from the test which I did wireless from my computer just now:
http://www.speedtest.net/my-result/2902515025
Why am I having a problem with the speed wirelessly and not wired? I have tried a wireless test from multiple items around my house ie. my computer, the family computer, my brother's computer and even my iPhone. All of which are coming up with similar poor results.
Does anyone know what may be the cause of this problem?
Thankyou,
Harry McIntosh.
5 REPLIES 5
Distinguished Expert
Message 2 of 6
Re: Problems with Wireless
To get good wireless you need to use wireless-n, 40mhz bandwidth, wpa2 security and aes encryption.
Looks like you're using wireless-g.
To say thanks for a helpful answer, please click the white star
MaccaHM
Message 3 of 6
How do I change it? If that's possible..
Message 4 of 6
Change the settings on the router
MaccaHM
Message 5 of 6
What do I change? I don't want to mess anything up
Message 6 of 6
You change the settings on the router to match the settings I have posted.
If you don't want to mess anything up, you will be better off leaving them alone and putting up with your current wireless speeds.
